Zum Hauptinhalt wechseln
Nokia Lumia 920 Back panel Replacement
Was du brauchst
  1. Nokia Lumia 920 Back panel Replacement, Remove the Bottom Screws: Schritt 1, Bild 1 von 3 Nokia Lumia 920 Back panel Replacement, Remove the Bottom Screws: Schritt 1, Bild 2 von 3 Nokia Lumia 920 Back panel Replacement, Remove the Bottom Screws: Schritt 1, Bild 3 von 3
    • Make sure the phone is off.
    • Use the T5 screwdriver to remove the two 8.6mm long screws, located at the bottom of the phone. (Head size is 2.5mm)
  2. Nokia Lumia 920 Back panel Replacement: Schritt 2, Bild 1 von 2 Nokia Lumia 920 Back panel Replacement: Schritt 2, Bild 2 von 2
    • Use the smallest Torx screwdriver or another small poking tool and push into the hole on the SIM card slot. The plastic SIM protective piece should pop out quite easily.
    • Put that plastic piece aside.
  3. Nokia Lumia 920 Back panel Replacement: Schritt 3, Bild 1 von 2 Nokia Lumia 920 Back panel Replacement: Schritt 3, Bild 2 von 2
    • Once both screws on the bottom are removed, and the plastic SIM protective piece is removed, gently push on the outside of the screen.
    • The screen should become separated using little force. And should like the pictures shown once complete.
  4. Nokia Lumia 920 Back panel Replacement: Schritt 4, Bild 1 von 2 Nokia Lumia 920 Back panel Replacement: Schritt 4, Bild 2 von 2
    • This step may be easier to remove the battery first, but it is not mandatory.
    • Place the spudger tool or flat plastic tool on top of the ribbon cable to avoid damaging it when prying up on the metal clip.
    • Use a plastic opening tool, or gently use a small metal flat-head screwdriver to pry up the metal clip. (It is recommended to use a plastic tool; However, if the opening tool does not work or fit into the small opening underneath the clip, use the flat-head.)
  5. Nokia Lumia 920 Back panel Replacement: Schritt 5, Bild 1 von 2 Nokia Lumia 920 Back panel Replacement: Schritt 5, Bild 2 von 2
    • Once the metal clip is removed, gently pry up on the ribbon cable connection, located underneath the metal clip you have just removed.
Abschluss
14 weitere Nutzer:innen haben diese Anleitung absolviert.
Jonathan
1.492 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 4-2, Miles Fall 2014 Mitglied von UMass Dartmouth, Team 4-2, Miles Fall 2014
UMASSD-MILES-F14S4G2
2 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
useless - doesnt show detail
nick - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 21
Insgesamt: 9,467
