Zum Hauptinhalt wechseln
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement
Was du brauchst
  1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
  2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement, RAM Shield: Schritt 2, Bild 1 von 1
    • Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  3. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement: Schritt 3, Bild 1 von 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement, Upper Case: Schritt 4, Bild 1 von 1
    • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  5. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement: Schritt 5, Bild 1 von 1
    • Remove the following six screws:
    • Two 14.5 mm T6 Torx screws on either side of the RAM slot.
    • Four 3.4 mm Phillips screws along the hinge.
  6. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement: Schritt 6, Bild 1 von 1
    • Remove the four 3.4 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement: Schritt 7, Bild 1 von 1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  8. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement: Schritt 8, Bild 1 von 1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement: Schritt 9, Bild 1 von 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  10. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board.
    • Remove the upper case.
  11. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement, Left I/O Board Cable: Schritt 11, Bild 1 von 1
    • Disconnect the hard drive ribbon cable and the left I/O board ribbon cable from the logic board.
    • Disconnect the right speaker connector from the left I/O board.
  12. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement: Schritt 12, Bild 1 von 1
    • Remove the two silver T6 Torx screws securing the gray metal retaining bracket to the right side of the hard drive.
    • Lift the gray metal retaining bracket out of the computer.
  13. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement: Schritt 13, Bild 1 von 1
    • Remove the five black T6 Torx screws securing the left I/O board to the lower case.
    • Disconnect the large power connector from the left I/O board.
  14. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement: Schritt 14, Bild 1 von 1
    • Move the orange hard drive ribbon out of the way with one hand. Use your other hand to lift up the right side of the left I/O board and slide it out of the computer.
  15. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable Replacement: Schritt 15, Bild 1 von 1
    • Turn the left I/O board over.
    • Use a spudger to disconnect the short orange cable from the left I/O board.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
iRobot
1 Reputation
636 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 19
Insgesamt: 7,926
