Zum Hauptinhalt wechseln
ZTE Awe Motherboard Replacement
Was du brauchst
  1. ZTE Awe Motherboard Replacement, Remove the back cover: Schritt 1, Bild 1 von 1
    • Remove the back cover of the phone to expose the phone's mid-frame.
  2. ZTE Awe Motherboard Replacement, Remove battery: Schritt 2, Bild 1 von 1
    • Pry the battery up and out of the phone.
  3. ZTE Awe Motherboard Replacement, Detach the mid frame: Schritt 3, Bild 1 von 1
    • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
  4. ZTE Awe Motherboard Replacement, Separate the mid frame and the digitizer: Schritt 4, Bild 1 von 3 ZTE Awe Motherboard Replacement, Separate the mid frame and the digitizer: Schritt 4, Bild 2 von 3 ZTE Awe Motherboard Replacement, Separate the mid frame and the digitizer: Schritt 4, Bild 3 von 3
    • Wedge the flat end of the spudger between the mid frame and the digitizer.
  5. ZTE Awe Motherboard Replacement, Expose the motherboard: Schritt 5, Bild 1 von 2 ZTE Awe Motherboard Replacement, Expose the motherboard: Schritt 5, Bild 2 von 2
    • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
  6. ZTE Awe Motherboard Replacement, Remove the ribbon wires: Schritt 6, Bild 1 von 3 ZTE Awe Motherboard Replacement, Remove the ribbon wires: Schritt 6, Bild 2 von 3 ZTE Awe Motherboard Replacement, Remove the ribbon wires: Schritt 6, Bild 3 von 3
    • Use the tweezers to remove the four ribbon wires on the sides of the device.
  7. ZTE Awe Motherboard Replacement, Orient the motherboard: Schritt 7, Bild 1 von 1
    • Orient the motherboard to expose the mid frame.
  8. ZTE Awe Motherboard Replacement, Remove the connector: Schritt 8, Bild 1 von 3 ZTE Awe Motherboard Replacement, Remove the connector: Schritt 8, Bild 2 von 3 ZTE Awe Motherboard Replacement, Remove the connector: Schritt 8, Bild 3 von 3
    • Remove the connector to free the motherboard from the screen.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Jennifer DeMeo
1.035 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-2, Leahy Fall 2014 Mitglied von USF Tampa, Team 1-2, Leahy Fall 2014
USFT-LEAHY-F14S1G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,886
