Zum Hauptinhalt wechseln
Brother PT-1010 Keyboard Replacement
Was du brauchst
  1. Brother PT-1010 Keyboard Replacement, Remove Back Cover: Schritt 1, Bild 1 von 1
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Brother PT-1010 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove batteries, cassette tape, and cutter blade.
  3. Brother PT-1010 Keyboard Replacement, Remove Screws: Schritt 3, Bild 1 von 1
    • Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
  4. Brother PT-1010 Keyboard Replacement, Separate Device: Schritt 4, Bild 1 von 1
    • Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
  5. Brother PT-1010 Keyboard Replacement, Remove side panels: Schritt 5, Bild 1 von 1
    • Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
  6. Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: Schritt 6, Bild 1 von 3 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: Schritt 6, Bild 2 von 3 Brother PT-1010 Keyboard Replacement, Pull Ribbon Out: Schritt 6, Bild 3 von 3
    • Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
  7. Brother PT-1010 Keyboard Replacement, Remove Screws from Circuit Board: Schritt 7, Bild 1 von 1
    • Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
  8. Brother PT-1010 Keyboard Replacement, Remove Circuit Board: Schritt 8, Bild 1 von 1
    • Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
    • The ribbon is very fragile so be careful to break it when pulling up on the circuit board.
  9. Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: Schritt 9, Bild 1 von 3 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: Schritt 9, Bild 2 von 3 Brother PT-1010 Keyboard Replacement, Peel Off Rubber Keyboard: Schritt 9, Bild 3 von 3
    • Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
Abschluss
Haley Sweet
460 Reputation
4 Anleitungen geschrieben
Baylor, Team 4-4, Williams Fall 2014 Mitglied von Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Mitglieder
3 Kommentare
Hi!
Thanks for this very helpful and detailed set of instructions. One small suggestion - assuming that replacing the keyboard means you need a working one to replace the old one with, you might want to consider adding “Parts: replacement keyboard” instead of “No parts required.”
Cheers,
Maria B
Maria Bitterli - Antwort
Please specify what is being replaced. Is the rubber keyboard the part that needs to be replaced?
Sincere Cavalier - Antwort
Screen is dull, what to do
Judy Baranczyk - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 32
Insgesamt: 3,027
