Was du brauchst
Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
Fast fertig!
Abschluss
