Zum Hauptinhalt wechseln
Samsung Galaxy Fame S6812i LCD Screen Replacement
Was du brauchst
  1. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the battery cover: Schritt 1, Bild 1 von 1
    • Make sure that the phone is turned off. Then use your thumb nail or a plastic spudger to pry open the back cover.
  2. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the battery: Schritt 2, Bild 1 von 1
    • Use your thumb nail or the plastic opening tool to lift the battery out of the device.
  3. Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the screws: Schritt 3, Bild 1 von 2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the screws: Schritt 3, Bild 2 von 2
    • Remove the five 4 mm screws with a Phillips#00 screwdriver
    • Note: One of the five screws is hidden under a sticker on the bottom left corner of the device.
  4. Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the mid-frame: Schritt 4, Bild 1 von 2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the mid-frame: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to pry into the bezel to separate the mid-frame from the device
    • Be gentle; the plastic mounting clips are very fragile. Take extra care when working around the volume button.
  5. Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the internal cover: Schritt 5, Bild 1 von 3 Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the internal cover: Schritt 5, Bild 2 von 3 Samsung Galaxy Fame S6812i LCD Screen Replacement, Removing the internal cover: Schritt 5, Bild 3 von 3
    • Use the Phillips#00 screwdriver to remove the five black screws.
    • Use the plastic opening tool to lift the two ribbons.
    • Remove the metal internal cover to expose the motherboard.
  6. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the motherboard: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool to lift the motherboard out of the device.
  7. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove and replace the LCD screen: Schritt 7, Bild 1 von 2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove and replace the LCD screen: Schritt 7, Bild 2 von 2
    • Once you have removed the motherboard you will have access to the LCD screen.
    • Use the plastic opening tool to remove the damaged LCD screen from the display assembly.
    • Put the new LCD screen in place and reassemble the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 8-2, Leahy Fall 2014 Mitglied von USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 953
