Zum Hauptinhalt wechseln
Asus V6800V RAM Replacement
Was du brauchst
  1. Asus V6800V RAM Replacement, Battery: Schritt 1, Bild 1 von 2 Asus V6800V RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V RAM Replacement, RAM: Schritt 2, Bild 1 von 1
    • On the back panel unscrew highlighted screws and carefully put them to the side as not to lose them.
  3. Asus V6800V RAM Replacement: Schritt 3, Bild 1 von 1
    • Locate the RAM chip and the two metal tabs holding it in place.
  4. Asus V6800V RAM Replacement: Schritt 4, Bild 1 von 1
    • Carefully use your thumbs to push out the metal tabs and the RAM should spring up.
  5. Asus V6800V RAM Replacement: Schritt 5, Bild 1 von 1
    • After the ram has sprung up, carefully grab the edges with your fingers and gently pull straight out.
  6. Asus V6800V RAM Replacement: Schritt 6, Bild 1 von 1
    • After you have gotten either more RAM or replacement RAM line up the pins and slot (highlighted red) in the RAM card with the pin on the computer.
    • Carefully insert the new ram in at the same angle that you removed it at.
    • The other side of the RAM slot is a place for more RAM if you want to put more in.
Abschluss
Connor
34 Reputation
1 Anleitung geschrieben
Cal Poly, Team 2-9, Johann Summer 2010 Mitglied von Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 3,348
