Zum Hauptinhalt wechseln
Motorola Photon 4G MB855 Speaker Replacement
Was du brauchst
  1. Motorola Photon 4G MB855 Speaker Replacement, Removing the Back Cover: Schritt 1, Bild 1 von 2 Motorola Photon 4G MB855 Speaker Replacement, Removing the Back Cover: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Speaker Replacement, Removing the Battery: Schritt 2, Bild 1 von 2 Motorola Photon 4G MB855 Speaker Replacement, Removing the Battery: Schritt 2, Bild 2 von 2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Speaker Replacement, Removing Screw Covers: Schritt 3, Bild 1 von 3 Motorola Photon 4G MB855 Speaker Replacement, Removing Screw Covers: Schritt 3, Bild 2 von 3 Motorola Photon 4G MB855 Speaker Replacement, Removing Screw Covers: Schritt 3, Bild 3 von 3
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Speaker Replacement, Removing the Midframe: Schritt 4, Bild 1 von 3 Motorola Photon 4G MB855 Speaker Replacement, Removing the Midframe: Schritt 4, Bild 2 von 3 Motorola Photon 4G MB855 Speaker Replacement, Removing the Midframe: Schritt 4, Bild 3 von 3
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Speaker Replacement, Locating the Speaker: Schritt 5, Bild 1 von 1
    • Locate the speaker on the back of the midframe.
  6. Motorola Photon 4G MB855 Speaker Replacement, Removing the Speaker: Schritt 6, Bild 1 von 2 Motorola Photon 4G MB855 Speaker Replacement, Removing the Speaker: Schritt 6, Bild 2 von 2
    • The speaker is attached to the midframe with adhesive. Remove carefully.
    • Use the Metal Spudger to get between the speaker and the midframe and slowly lift the speaker upwards.
    • Remove the speaker from the midframe.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 8-6, Leahy Fall 2014 Mitglied von USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 8
Letzte 30 Tage: 8
Insgesamt: 373
