Zum Hauptinhalt wechseln
Asus V6800V CD/DVD Drive Replacement
Was du brauchst
  1. Asus V6800V CD/DVD Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Asus V6800V CD/DVD Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V CD/DVD Drive Replacement, Hard Drive: Schritt 2, Bild 1 von 2 Asus V6800V CD/DVD Drive Replacement, Hard Drive: Schritt 2, Bild 2 von 2
    • Remove the two screws using a Phillips #0 screwdriver.
  3. Asus V6800V CD/DVD Drive Replacement: Schritt 3, Bild 1 von 2 Asus V6800V CD/DVD Drive Replacement: Schritt 3, Bild 2 von 2
    • Pry open the case using an iFixit opening tool.
    • Actual hard drive is not shown in the second image.
  4. Asus V6800V CD/DVD Drive Replacement: Schritt 4, Bild 1 von 2 Asus V6800V CD/DVD Drive Replacement: Schritt 4, Bild 2 von 2
    • The highlighted area is where your hard drive would be. Slide it out away from its slot and pull it gently to remove.
    • Second image shows what it should look like once you remove the hard drive.
  5. Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: Schritt 5, Bild 1 von 2 Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: Schritt 5, Bild 2 von 2
    • Remove the screw from the bottom right corner using a Phillips #0 screwdriver.
    • Insert a spudger into the hole to carefully push the CD/DVD drive out.
Abschluss
To reassemble your device, just push the new CD/DVD driver back. Then put the components back together then put the screws back in.
Jong Park
114 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 2-9, Johann Summer 2010 Mitglied von Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 4,260
