Zum Hauptinhalt wechseln
Smart Tweezers and LCR-Reader LCR-meter Screen Replacement
Was du brauchst
  1. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: Schritt 1, Bild 1 von 2 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: Schritt 1, Bild 2 von 2
    • Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver.
  2. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: Schritt 2, Bild 1 von 2 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: Schritt 2, Bild 2 von 2
    • Gently open the zif connector that holds the screen.
    • Insert the replacement screen, and close the zif
  3. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Closing the device: Schritt 3, Bild 1 von 1
    • When closing the housing, make sure the screen fits into the rectangle on the top.
    • If the screen is not in this rectangle, it may become damaged when the screws are tightened
    • Hold the screen in place from below; line up the button's edge of the top housing to line up with the bottom housing. Slide your finger out as you bring the top and bottom housings to meet.
    • Replace the 4 Philips screws in the back.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
brittany
234 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 456
