Zum Hauptinhalt wechseln
Kodak EasyShare LS743 Battery Door Replacement
Was du brauchst
  1. Kodak EasyShare LS743 Battery Door Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Battery Door Replacement: Schritt 2, Bild 1 von 1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: Schritt 3, Bild 1 von 3 Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: Schritt 3, Bild 2 von 3 Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: Schritt 3, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Battery Door Replacement: Schritt 4, Bild 1 von 3 Kodak EasyShare LS743 Battery Door Replacement: Schritt 4, Bild 2 von 3 Kodak EasyShare LS743 Battery Door Replacement: Schritt 4, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Battery Door Replacement: Schritt 5, Bild 1 von 2 Kodak EasyShare LS743 Battery Door Replacement: Schritt 5, Bild 2 von 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Battery Door Replacement, Battery Door: Schritt 6, Bild 1 von 2 Kodak EasyShare LS743 Battery Door Replacement, Battery Door: Schritt 6, Bild 2 von 2
    • Remove loose battery door.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Odessa
55 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 2-8, Johann Summer 2010 Mitglied von Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 11
Insgesamt: 1,709
