Einleitung
This will show a step-by-step process in replacing the microphone from your Kodak EasyShare LS743 Prior to beginning the guide, but sure to remove the batteries from the device.
A warning for this guide: you will need to solder at the end of the guide to remove the microphone so if you don't know how or need a refresher, check out the How to Solder and Desolder Connections article.
Was du brauchst
Slide the orange latch sideways to eject the battery.
Remove the battery from the battery slot.
Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
Remove the metal piece holding down the lanyard, then remove the lanyard.
Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
One 6.25 mm screw is located on the top right corner, right to the "OK" button.
Four 4.45 mm screws are on the bottom of the camera.
Two 2.95 mm screws are on the left side of the camera, above the USB port.
Carefully remove the rear camera casing.
Carefully remove the front camera casing.
Flip up the LCD screen to reveal the two orange ribbon cables.
Disconnect the two ribbons cables from their sockets on the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
