Zum Hauptinhalt wechseln
Samsung Galaxy Attain 4G Rear Housing Replacement
Was du brauchst
  1. Samsung Galaxy Attain 4G Rear Housing Replacement, Placement: Schritt 1, Bild 1 von 1
    • Begin by turn the device over to it's back, with the screen facing down.
  2. Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Door Removal: Schritt 2, Bild 1 von 2 Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Door Removal: Schritt 2, Bild 2 von 2
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Removal: Schritt 3, Bild 1 von 3 Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Removal: Schritt 3, Bild 2 von 3 Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Removal: Schritt 3, Bild 3 von 3
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Samsung Galaxy Attain 4G Rear Housing Replacement, Heads Up!: Schritt 4, Bild 1 von 1
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
  5. Samsung Galaxy Attain 4G Rear Housing Replacement, Screw Removal: Schritt 5, Bild 1 von 1
    • Remove the 6 Phillips head screws that hold the rear housing in place.
  6. Samsung Galaxy Attain 4G Rear Housing Replacement, Prying: Schritt 6, Bild 1 von 1
    • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
  7. Samsung Galaxy Attain 4G Rear Housing Replacement, Remove Housing: Schritt 7, Bild 1 von 1
    • Lift the rear housing from the display assembly.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Josh Forester
2.497 Reputation
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 293
