Einleitung
The Streak is new to the ever-expanding Android smartphone market. The behemoth also happens to be Dell's first smartphone, so we felt it proper to give it the royal iFixit treatment and see what makes it tick.
This is also the first device to receive a subjective "repairability" score from iFixit. We're listing the good and not-so-good repair aspects of the phone (as well as its score) in the final step of the teardown. Check it out!
Was du brauchst
At long last, the Dell Streak has arrived on American soil. More importantly, it has landed in the hands of iFixit. And we all know what that means...
The Dell Streak features:
5" 800x480 TFT LCD Display
5 MP rear-facing camera and VGA front-facing camera
Android 1.6 (Donut) operating system
1 GHz Qualcomm 8250 Snapdragon processor
Corning Gorilla Glass front panel
After the rear panel is gone, the battery can be easily removed from its home.
The Streak's 3.7 V 1530 mAh (5.66 Whr) battery reportedly powers the gargantuan device for...well...we don't know how long.
The inner face of the battery is covered with a sheet of steel, rather than plastic, to decrease its overall thickness. Perhaps the Streak also doubles as body armor?
After the battery is removed, the pre-installed 16 GB microSD card can be slid out of its socket.
There you have it for Dell's approved user serviceability. Now let's void some warranties!
A plastic opening tool is all that's needed to remove the bezel securely stuck to the top edge of the Streak.
We found the screws! This is a good sign.
Similarly, the lower bezel can be easily pried up from body of the Streak.
Since the connector is inside the device, it's a good idea to leave the bezel attached for now.
After a bit of digging, the five T5 Torx screws securing the rear case can be removed.
After some light prying with a plastic opening tool, the rear case comes off with ease.
The rear case houses many components, including:
LED flash
Headphone jack
Loudspeaker (for speakerphone)
Antennas
The digging continues as we remove a small plastic bezel attached to the lower edge of the motherboard.
At this point, both the front-facing and rear-facing cameras can be disconnected from the motherboard.
Before lifting out the motherboard, the touchscreen, LCD, and control button ribbon cables must be disconnected.
The "C"-shaped motherboard comes out easily. Rather than using daughterboards like the Droid 2, the Streak has all components attached to this singular motherboard.
A 2 GB non-user accessible microSD card can be seen near the top of the motherboard.
This card is used to house system & applications files only, and Dell doesn't want you to remove it.
Big players on the motherboard include:
Qualcomm QSD8250 Snapdragon processor
Analog Devices ADV7520 Low Power HDMI™/DVI Transmitter
Hynix H8BES0UU0MCR NAND-based MCP
Qualcomm MXU6219 RF Transceiver
Qualcomm PM7540 Power Management chip
TriQuint Semiconductor TQS 7M5012 Power Amp (Quad-band GSM)
Texas Instruments TPS 65023 Integrated Power Management IC
The back of the motherboard is relatively featureless, with a few notable exceptions:
Microphone
Pressure contacts for the capacitive controls on the lower bezel
Proximity sensors to tell the touchscreen when your face is pressed against it
Ambient light sensor for the front-facing camera.
Sadly, the Streak's LCD is permanently adhered to the front panel glass. However, that LCD/glass subassembly is held in the front panel with very strong 3M adhesive, and could be removed with enough careful prying.
The inner face of the front panel assembly isn't all that exciting. The ear speaker and vibrator motor can be seen near its top edge.
The touchscreen ribbon cable houses:
Pixcir's controversial Tango S32 Touchscreen controller
Atmel's ATmega168P 8-bit AVR microcontroller
Dell Streak Repairability: 8 out of 10 (10 is easiest to repair)
Good: Replacing the battery is super easy and takes less than one minute.
Good: Opening the device requires prying the bezels and removing five screws.
Good: Cables use standard connectors, including our favorite, ZIF connectors.
Neutral: The rear panel feels cheap and deforms easily for a $600 device.
Bad: The LCD is bonded to the Gorilla Glass, increasing the cost of fixing the device if you break just the glass.
2 Kommentare
my screen broke after a final hard drop a few months ago (weather and ground are cold now) and not going to get it fixed. it was dropped quite a bit and held up pretty good... i can make great use of the bonus [hidden/second] memory card inside :)
thanks for the great pics and detailed teardown :)
my mobile led is damage so you have to change my led.
