Zum Hauptinhalt wechseln
Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning
Was du brauchst
Einführungsvideo
  1. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, HDD Cover: Schritt 1, Bild 1 von 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, HDD Cover: Schritt 1, Bild 2 von 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, HDD Cover: Schritt 1, Bild 3 von 3
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, Fan / Cooling System: Schritt 2, Bild 1 von 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, Fan / Cooling System: Schritt 2, Bild 2 von 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning, Fan / Cooling System: Schritt 2, Bild 3 von 3
    • Disconnect the Fan cable.
    • Remove the 2x screws from the Fan module.
    • Unscrew 4x screws around the processor.
    • Carefully lift the Cooling System.
  3. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: Schritt 3, Bild 1 von 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: Schritt 3, Bild 2 von 3 Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: Schritt 3, Bild 3 von 3
    • Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Separate the Fan from the Heat-sink.
  4. Lenovo ThinkPad Edge E530 Fan / Cooling System Replacement / Cleaning: Schritt 4, Bild 1 von 1
    • Use a soft anti static brush and clean the Heat-sink on the inside.
    • Before installing a new Cooling System or reinstalling the old one, you must clean the processor from the old thermal compound and put a new one.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.341 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.541 Anleitungen geschrieben
3 Kommentare
Very, very well done video on this guide for the Lenovo Thinkpad e530 laptop.
My compliments to the author of this guide.
James Harnsberger - Antwort
will i need thermal paste to do this?
dErpyto3z Eeee - Antwort
thanks its clear
Kayan Dev - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 13
Letzte 30 Tage: 22
Insgesamt: 8,027
