Zum Hauptinhalt wechseln
Oculus Rift DK1 Control Box Buttons Replacement
Was du brauchst
  1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: Schritt 1, Bild 1 von 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: Schritt 1, Bild 2 von 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: Schritt 1, Bild 3 von 3
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
  2. Oculus Rift DK1 Control Box Buttons Replacement: Schritt 2, Bild 1 von 3 Oculus Rift DK1 Control Box Buttons Replacement: Schritt 2, Bild 2 von 3 Oculus Rift DK1 Control Box Buttons Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
  3. Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: Schritt 3, Bild 1 von 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: Schritt 3, Bild 2 von 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: Schritt 3, Bild 3 von 3
    • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
    • When the DVI connector has cleared the casing, lift the motherboard.
    • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
    • When reassembling the device, ensure that all of the wires are clear of the buttons.
  4. Oculus Rift DK1 Control Box Buttons Replacement: Schritt 4, Bild 1 von 3 Oculus Rift DK1 Control Box Buttons Replacement: Schritt 4, Bild 2 von 3 Oculus Rift DK1 Control Box Buttons Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
    • Do so for both of the wires attached to the motherboard.
    • Now fully separate the motherboard from the control box casing.
  5. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Buttons: Schritt 5, Bild 1 von 1
    • You now have the motherboard separated from the control box.
    • Identify the buttons that are not working.
  6. Oculus Rift DK1 Control Box Buttons Replacement, Desoldering Button: Schritt 6, Bild 1 von 1
    • For each button that needs to be replaced, use a soldering iron and soldering braid to desolder the four metal points.
    • Be careful! Soldering iron is hot.
  7. Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: Schritt 7, Bild 1 von 2 Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: Schritt 7, Bild 2 von 2
    • Now that each button with issues is desoldered, use tweezers to grab each button and detach from the motherboard.
    • If the button does not come off easily, go back to the previous step and ensure each of the four metal points are properly desoldered.
Abschluss
Ross De Vito
225 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 70-5, Forte Winter 2015 Mitglied von Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 549
