Zum Hauptinhalt wechseln
DJI Phantom Propeller Replacement
Was du brauchst
  1. DJI Phantom Propeller Replacement, Open the Battery Compartment: Schritt 1, Bild 1 von 3 DJI Phantom Propeller Replacement, Open the Battery Compartment: Schritt 1, Bild 2 von 3 DJI Phantom Propeller Replacement, Open the Battery Compartment: Schritt 1, Bild 3 von 3
    • Press down on battery door release tab to flip the battery door open.
  2. DJI Phantom Propeller Replacement, Remove the Battery: Schritt 2, Bild 1 von 3 DJI Phantom Propeller Replacement, Remove the Battery: Schritt 2, Bild 2 von 3 DJI Phantom Propeller Replacement, Remove the Battery: Schritt 2, Bild 3 von 3
    • Pull out the battery pack.
    • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
  3. DJI Phantom Propeller Replacement, Disconnect the Battery: Schritt 3, Bild 1 von 2 DJI Phantom Propeller Replacement, Disconnect the Battery: Schritt 3, Bild 2 von 2
    • Pull the two halves of the XT60 power connector apart.
    • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
  4. DJI Phantom Propeller Replacement, Identifying Silver and Black Collets: Schritt 4, Bild 1 von 2 DJI Phantom Propeller Replacement, Identifying Silver and Black Collets: Schritt 4, Bild 2 von 2
    • Silver-topped propeller collets unscrew counter-clockwise
    • Black-topped propeller collets unscrew clockwise
  5. DJI Phantom Propeller Replacement, Unscrewing Silver Collets: Schritt 5, Bild 1 von 3 DJI Phantom Propeller Replacement, Unscrewing Silver Collets: Schritt 5, Bild 2 von 3 DJI Phantom Propeller Replacement, Unscrewing Silver Collets: Schritt 5, Bild 3 von 3
    • For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction.
    • Once free, unscrew and remove the collet.
  6. DJI Phantom Propeller Replacement, Unscrewing Black Collets: Schritt 6, Bild 1 von 3 DJI Phantom Propeller Replacement, Unscrewing Black Collets: Schritt 6, Bild 2 von 3 DJI Phantom Propeller Replacement, Unscrewing Black Collets: Schritt 6, Bild 3 von 3
    • For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction.
  7. DJI Phantom Propeller Replacement, Remove the Propeller: Schritt 7, Bild 1 von 3 DJI Phantom Propeller Replacement, Remove the Propeller: Schritt 7, Bild 2 von 3 DJI Phantom Propeller Replacement, Remove the Propeller: Schritt 7, Bild 3 von 3
    • Gently press down the motor shaft and lift the propeller up to remove it.
Abschluss
David Hoyt
4.023 Reputation
43 Anleitungen geschrieben
Cal Poly, Team 25-89, Amido Spring 2010 Mitglied von Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Mitglieder
63 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 1,268
