Zum Hauptinhalt wechseln
Alternative Opening Procedure
Was du brauchst
  1. Alternative Opening Procedure, Alternative Opening Procedure: Schritt 1, Bild 1 von 1
    • Instead of a putty knife a dozen or more 1-1/2" pins are required.
  2. Alternative Opening Procedure: Schritt 2, Bild 1 von 2 Alternative Opening Procedure: Schritt 2, Bild 2 von 2
    • With the computer upside down identify the apertures where the catches are located along either side and also at the front.
    • Insert the pins from the adjacent apertures between the wall and each catch. Be very careful to keep the pins against the case wall. This is more obvious from the second photo with the case removed.
  3. Alternative Opening Procedure: Schritt 3, Bild 1 von 1
    • Lift the case off from the back first.
    • Remove the pins from the main assembly.
Abschluss
Re-assembly does not require the pins. Place the case over the computer and press down evenly on the sides, not the middle. Ensure the back panel is correctly aligned before finally pushing home the catches.
16 weitere Nutzer:innen haben diese Anleitung absolviert.
Donald Todd
528 Reputation
1 Anleitung geschrieben
Ein Kommentar
I've recently acquired a G4 Mini 1.33 "Silent Upgrade" on eBay and plan on opening up using your guide :) Thanks so very, VERY much!
Tyler Regas - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 33
Insgesamt: 15,057
