Einleitung
Use this guide to replace your iPod Nano's outer casing.
Was du brauchst
Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
While the front panel is still warm, use the edge of an opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
Lift the front panel assembly from the headphone jack side of the Nano.
Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
Lay the front panel assembly next to the Nano.
Remove the following two screws:
One 2.3 mm Phillips screw
One 2.6 mm shouldered Phillips screw
Use an opening tool to pry the steel shield out of the Nano by its upper right corner.
Remove the steel shield from the Nano.
Use an opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board.
Use an iPod opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
Remove the single 1.9 mm Phillips screw securing the logic board to the outer case.
Use an iPod opening tool to gently pry the battery up from the adhesive securing it to the outer case.
Use your thumb to pull the battery toward the left side of the Nano as you pry the battery's other edge out of the outer case.
Use an iPod opening tool to gently pry the logic board off the adhesive holding it against the outer case.
Use your iPod opening tool to gently push the dock connector toward the center of the Nano.
Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
Remove the following five screws:
One 1.7 mm Phillips screw
Four 3.9 mm Phillips screws.
Very carefully pull the headphone jack assembly ribbon cable toward the dock connector to separate the sleep and volume buttons from the outer case.
Remove the headphone jack assembly.
Remove the following three screws:
One black 1.8 mm Phillips screw
Two 1.7 mm Phillips screws
13 weitere Nutzer:innen haben diese Anleitung absolviert.
