Einleitung
Use this guide to remove the light bulb from your Optoma HD20.
Was du brauchst
Use a Phillips #1 screwdriver to loosen the screws that secure the panel on the bottom of the Optoma HD20.
Use a Phillips #1 screwdriver to loosen the two screws securing the black casing.
Remove the 4 screws on the back of the light bulb casing using a Phillips #1 screwdriver.
Remove the casing, then gently pull out the old light bulb and replace it with the new one.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
king@okinlamps.com
Need LAD60 20PCS
The manual says the new light won’t come back on until a lamp reset I’d done via menu , but how can you see the text if the light isn’t on?????
