Zum Hauptinhalt wechseln
Samsung Admire Camera Replacement
Was du brauchst
  1. Samsung Admire Camera Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Use your fingernail or the plastic opening tool under the slit to pull the back cover off.
  2. Samsung Admire Camera Replacement, Remove the Battery: Schritt 2, Bild 1 von 1
    • Making sure your hands are dry, insert your fingernail beneath the battery and remove it.
  3. Samsung Admire Camera Replacement, Remove the screws: Schritt 3, Bild 1 von 3 Samsung Admire Camera Replacement, Remove the screws: Schritt 3, Bild 2 von 3 Samsung Admire Camera Replacement, Remove the screws: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Use a Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
    • Place the screws on a magnetic mat to prevent losing them.
  4. Samsung Admire Camera Replacement, Inside back Cover: Schritt 4, Bild 1 von 3 Samsung Admire Camera Replacement, Inside back Cover: Schritt 4, Bild 2 von 3 Samsung Admire Camera Replacement, Inside back Cover: Schritt 4, Bild 3 von 3
    • Place the Plastic Opening tool on the outside rim of the back cover.
    • Carefully circle around the rim to open the inside back cover completely.
    • Disconnect the ribbon cables and remove the back cover.
  5. Samsung Admire Camera Replacement, Motherboard: Schritt 5, Bild 1 von 3 Samsung Admire Camera Replacement, Motherboard: Schritt 5, Bild 2 von 3 Samsung Admire Camera Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Carefully disconnect the volume button, the microphone connector, and the screen connector from the motherboard.
    • Pull back the side clips and lift the motherboard slowly.
  6. Samsung Admire Camera Replacement, Camera: Schritt 6, Bild 1 von 2 Samsung Admire Camera Replacement, Camera: Schritt 6, Bild 2 von 2
    • Use the plastic opening tool to disconnect the camera from the phone.
    • Connect the new camera into the motherboard.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Thao Uyen Do
896 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 7-5, Remmell Winter 2015 Mitglied von USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 1,490
