Zum Hauptinhalt wechseln
Samsung Admire Motherboard Replacement
Was du brauchst
  1. Samsung Admire Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • To open the back cover of the phone, use your fingernail or plastic opening tool under the slit to pull the cover up.
  2. Samsung Admire Motherboard Replacement, Remove Battery: Schritt 2, Bild 1 von 1
    • Carefully remove the battery by placing your fingernail underneath the hole and pull out the battery.
    • Your hands should not be wet.
  3. Samsung Admire Motherboard Replacement, Remove the screws: Schritt 3, Bild 1 von 3 Samsung Admire Motherboard Replacement, Remove the screws: Schritt 3, Bild 2 von 3 Samsung Admire Motherboard Replacement, Remove the screws: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
    • Be careful not to lose the screws, so place them on a magnetic mat.
  4. Samsung Admire Motherboard Replacement, Inside back cover: Schritt 4, Bild 1 von 3 Samsung Admire Motherboard Replacement, Inside back cover: Schritt 4, Bild 2 von 3 Samsung Admire Motherboard Replacement, Inside back cover: Schritt 4, Bild 3 von 3
    • Use the Plastic Opening tools to remove the inside back cover.
    • Place the Plastic Opening tools on the outside rim of the inside back cover.
    • Carefully lift the cover and circle around the rim to open the inside back cover completely.
    • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 3 Samsung Admire Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 3 Samsung Admire Motherboard Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Lift the motherboard slowly.
    • Carefully disconnect the volume button away from the motherboard.
    • Disconnect the two ribbon cables from the back of the motherboard.
    • Remove the motherboard completely from the phone
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Thao Uyen Do
896 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 7-5, Remmell Winter 2015 Mitglied von USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 1,304
