Zum Hauptinhalt wechseln
Eclipse 180G2 Outer Case Replacement
Was du brauchst
  1. Eclipse 180G2 Outer Case Replacement, Outer Case: Schritt 1, Bild 1 von 2 Eclipse 180G2 Outer Case Replacement, Outer Case: Schritt 1, Bild 2 von 2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: Schritt 2, Bild 1 von 3 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: Schritt 2, Bild 2 von 3 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: Schritt 2, Bild 3 von 3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Jesse Minor
662 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 1-4, Tanski Winter 2015 Mitglied von USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
What if there is no charge port or USB port there no longer?
May 303 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,328
