Zum Hauptinhalt wechseln
Kyocera Event Rear Assembly Replacement
Was du brauchst
  1. Kyocera Event Rear Assembly Replacement, Battery: Schritt 1, Bild 1 von 3 Kyocera Event Rear Assembly Replacement, Battery: Schritt 1, Bild 2 von 3 Kyocera Event Rear Assembly Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Rear Assembly Replacement: Schritt 2, Bild 1 von 1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event Rear Assembly Replacement, Locate the SIM card: Schritt 3, Bild 1 von 1
    • The SIM card slot can be seen in the middle left of the photograph.
  4. Kyocera Event Rear Assembly Replacement, Open slot and remove card: Schritt 4, Bild 1 von 2 Kyocera Event Rear Assembly Replacement, Open slot and remove card: Schritt 4, Bild 2 von 2
    • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
    • The gold tipped tines are what read the SD card along its bottom.
  5. Kyocera Event Rear Assembly Replacement, Remove the screws.: Schritt 5, Bild 1 von 2 Kyocera Event Rear Assembly Replacement, Remove the screws.: Schritt 5, Bild 2 von 2
    • Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
  6. Kyocera Event Rear Assembly Replacement, Remove the back assembly: Schritt 6, Bild 1 von 3 Kyocera Event Rear Assembly Replacement, Remove the back assembly: Schritt 6, Bild 2 von 3 Kyocera Event Rear Assembly Replacement, Remove the back assembly: Schritt 6, Bild 3 von 3
    • Pry the back assembly away from the body on all four sides of the phone.
    • Start prying at the top and work around.
    • Remove the buttons for the volume and power-this will allow for easier disassembly.
    • The back assembly is firmly attached to the body of the phone so removing it will require some force.
Abschluss
Philip
7 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-4, Michaels Spring 2015 Mitglied von Ohio State, Team 1-4, Michaels Spring 2015
OSU-MICHAELS-S15S1G4
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 791
