Zum Hauptinhalt wechseln
eMac RAM Replacement
Was du brauchst
  1. eMac RAM Replacement, RAM: Schritt 1, Bild 1 von 3 eMac RAM Replacement, RAM: Schritt 1, Bild 2 von 3 eMac RAM Replacement, RAM: Schritt 1, Bild 3 von 3
    • The 700MHz thru the second 1 GHz models use PC 133 sticks. The maximum RAM is 1 GB. The second two 1 GHz models and higher machines use PC 2700 memory sticks and have a maximum RAM of 2GB.
    • Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
  2. eMac RAM Replacement: Schritt 2, Bild 1 von 2 eMac RAM Replacement: Schritt 2, Bild 2 von 2
    • The access panel is held in place by one Phillips screw. Unscrew it.
    • Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
  3. eMac RAM Replacement: Schritt 3, Bild 1 von 2 eMac RAM Replacement: Schritt 3, Bild 2 von 2
    • There are two RAM slots. Release the RAM by pushing the white outer tabs. Then pull the RAM straight out.
    • Place new RAM in slots and press with both thumbs on each end till you feel them seat.
    • Replace the access panel. Turn it over and plug it in. Boot the machine up and click the Apple logo in the menu bar and then go to "about this Mac", to check to see that the RAM is being recognised properly.
Abschluss
29 weitere Nutzer:innen haben diese Anleitung absolviert.
mayer
685.268 Reputation
12 Anleitungen geschrieben
MacHale Enterprises Mitglied von MacHale Enterprises
Business
1 Mitglied
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 29
Insgesamt: 20,976
