Zum Hauptinhalt wechseln
Polaroid S7 Battery Replacement
Was du brauchst
  1. Polaroid S7 Battery Replacement, Remove the back: Schritt 1, Bild 1 von 2 Polaroid S7 Battery Replacement, Remove the back: Schritt 1, Bild 2 von 2
    • Insert the flat end of a soft plastic opening tool between the screen and the back cover.
    • Pry the two pieces apart.
    • Take care not to rip the ribbons that connect the screen to the back cover.
  2. Polaroid S7 Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a metal spudger to remove the orange sticker.
  3. Polaroid S7 Battery Replacement: Schritt 3, Bild 1 von 1
    • Use the screwdriver to remove the 2 x 4 mm Phillips #00 head screws from the blue board located on the lower-right corner of the battery.
  4. Polaroid S7 Battery Replacement: Schritt 4, Bild 1 von 2 Polaroid S7 Battery Replacement: Schritt 4, Bild 2 von 2
    • Use the metal spudger to remove the three pieces of clear tape adhering from the battery to the blue board.
    • Pry the battery up from the right side.
  5. Polaroid S7 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the yellow plastic that covers the battery connector.
  6. Polaroid S7 Battery Replacement: Schritt 6, Bild 1 von 1
    • Use a soldering iron to remove the wires connected to the battery.
Abschluss
USF Tampa, Team 1-2, Blackwell Winter 2015 Mitglied von USF Tampa, Team 1-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 3,225
