Zum Hauptinhalt wechseln
Nokia X Rear-Facing Camera Replacement
Was du brauchst
  1. Nokia X Rear-Facing Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
  2. Nokia X Rear-Facing Camera Replacement: Schritt 2, Bild 1 von 1
    • To remove the battery, simply use your finger to pry the battery out of its slot.
  3. Nokia X Rear-Facing Camera Replacement: Schritt 3, Bild 1 von 1
    • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
  4. Nokia X Rear-Facing Camera Replacement, Display Assembly: Schritt 4, Bild 1 von 2 Nokia X Rear-Facing Camera Replacement, Display Assembly: Schritt 4, Bild 2 von 2
    • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
    • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
  5. Nokia X Rear-Facing Camera Replacement: Schritt 5, Bild 1 von 2 Nokia X Rear-Facing Camera Replacement: Schritt 5, Bild 2 von 2
    • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
  6. Nokia X Rear-Facing Camera Replacement: Schritt 6, Bild 1 von 1
    • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
  7. Nokia X Rear-Facing Camera Replacement, Remove Camera: Schritt 7, Bild 1 von 3 Nokia X Rear-Facing Camera Replacement, Remove Camera: Schritt 7, Bild 2 von 3 Nokia X Rear-Facing Camera Replacement, Remove Camera: Schritt 7, Bild 3 von 3
    • Use a spudger to disconnect the rear-facing camera ribbon cable connector from the motherboard.
    • Remove the camera module by merely picking it up out of its housing slot.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Avery Dorsey
1.894 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 6-1, Brown Winter 2015 Mitglied von USF Tampa, Team 6-1, Brown Winter 2015
USFT-BROWN-W15S6G1
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 992
