Zum Hauptinhalt wechseln
Optoma HD20 Air Filter Replacement
Was du brauchst
  1. Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: Schritt 1, Bild 1 von 2 Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: Schritt 1, Bild 2 von 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Optoma HD20 Air Filter Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Air Filter Replacement: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Air Filter Replacement: Schritt 4, Bild 1 von 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
  5. Optoma HD20 Air Filter Replacement, Air Filter: Schritt 5, Bild 1 von 3 Optoma HD20 Air Filter Replacement, Air Filter: Schritt 5, Bild 2 von 3 Optoma HD20 Air Filter Replacement, Air Filter: Schritt 5, Bild 3 von 3
    • Carefully peel off each air filter from the device
    • Pull up on the air filter to remove it.
  6. Optoma HD20 Air Filter Replacement: Schritt 6, Bild 1 von 1
    • Remove the air filter from the device.
    • Try not to deposit dirt from the air filter into the inside of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Trever
1.264 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 21-23, Maness Winter 2015 Mitglied von Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Mitglieder
Ein Kommentar
There were no filters where the photos indicate.
Michael - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 56
Insgesamt: 12,040
