Zum Hauptinhalt wechseln
Acer Aspire R7 Battery Replacement
Was du brauchst
  1. Acer Aspire R7 Battery Replacement, Cover: Schritt 1, Bild 1 von 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Battery Replacement: Schritt 2, Bild 1 von 3 Acer Aspire R7 Battery Replacement: Schritt 2, Bild 2 von 3 Acer Aspire R7 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Battery Replacement: Schritt 3, Bild 1 von 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Battery Replacement, Battery: Schritt 4, Bild 1 von 2 Acer Aspire R7 Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Locate the battery ribbon connector
    • Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
    • When using the spudger be careful around the motherboard as it can easily be damaged
  5. Acer Aspire R7 Battery Replacement: Schritt 5, Bild 1 von 3 Acer Aspire R7 Battery Replacement: Schritt 5, Bild 2 von 3 Acer Aspire R7 Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove the three 4.5mm #00 Phillips screws attaching the battery to the motherboard
    • Push the 4 retaining clips away from the battery
    • Carefully lift the battery from the motherboard
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
F Fernandez
435 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 3-4, Hickman Winter 2015 Mitglied von USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Mitglieder
7 Anleitungen geschrieben
6 Kommentare
great instructions
amaryheart7777777 - Antwort
What is the battery reference for replacement ?
skalpinou - Antwort
which battery model do I purchase for replacing on an Acer Aspire R?
Eddie - Antwort
hey how do you want då sel it for
Alex santos - Antwort
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
Anthymoine - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 37
Insgesamt: 41,159
