Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-W290 casing Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-W290 casing Replacement, Battery: Schritt 1, Bild 1 von 1
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Sony Cyber-shot DSC-W290 casing Replacement: Schritt 2, Bild 1 von 1
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Sony Cyber-shot DSC-W290 casing Replacement, Outer Casing: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-W290 casing Replacement, Outer Casing: Schritt 3, Bild 2 von 2
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Sony Cyber-shot DSC-W290 casing Replacement: Schritt 4, Bild 1 von 3 Sony Cyber-shot DSC-W290 casing Replacement: Schritt 4, Bild 2 von 3 Sony Cyber-shot DSC-W290 casing Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Sony Cyber-shot DSC-W290 casing Replacement: Schritt 5, Bild 1 von 3 Sony Cyber-shot DSC-W290 casing Replacement: Schritt 5, Bild 2 von 3 Sony Cyber-shot DSC-W290 casing Replacement: Schritt 5, Bild 3 von 3
    • Turn the camera so the right side faces you.
  6. Sony Cyber-shot DSC-W290 casing Replacement: Schritt 6, Bild 1 von 1
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Sony Cyber-shot DSC-W290 casing Replacement: Schritt 7, Bild 1 von 2 Sony Cyber-shot DSC-W290 casing Replacement: Schritt 7, Bild 2 von 2
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Sony Cyber-shot DSC-W290 casing Replacement: Schritt 8, Bild 1 von 2 Sony Cyber-shot DSC-W290 casing Replacement: Schritt 8, Bild 2 von 2
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Sony Cyber-shot DSC-W290 casing Replacement: Schritt 9, Bild 1 von 2 Sony Cyber-shot DSC-W290 casing Replacement: Schritt 9, Bild 2 von 2
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Sony Cyber-shot DSC-W290 casing Replacement: Schritt 10, Bild 1 von 2 Sony Cyber-shot DSC-W290 casing Replacement: Schritt 10, Bild 2 von 2
    • This is what your camera should look like now that you have removed the casing from all sides.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Evan Mayer
318 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 7-54, Amido Fall 2010 Mitglied von Cal Poly, Team 7-54, Amido Fall 2010
CPSU-AMIDO-F10S7G54
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 1,834
