Zum Hauptinhalt wechseln
Asus X200MA Fan Replacement
Was du brauchst
  1. Asus X200MA Fan Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Fan Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Fan Replacement, Battery: Schritt 3, Bild 1 von 1
    • Take two rubber caps off the back side of the laptop.
  4. Asus X200MA Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  5. Asus X200MA Fan Replacement: Schritt 5, Bild 1 von 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  6. Asus X200MA Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  7. Asus X200MA Fan Replacement: Schritt 7, Bild 1 von 1
    • Slide the battery up and out.
  8. Asus X200MA Fan Replacement, Fan: Schritt 8, Bild 1 von 1
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
  9. Asus X200MA Fan Replacement: Schritt 9, Bild 1 von 2 Asus X200MA Fan Replacement: Schritt 9, Bild 2 von 2
    • Unplug the set of wires located at bottom corner on fan.
  10. Asus X200MA Fan Replacement: Schritt 10, Bild 1 von 2 Asus X200MA Fan Replacement: Schritt 10, Bild 2 von 2
    • Lift up and out to completely the remove fan component.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Vanessa Garcia
1.763 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 21-24, Maness Winter 2015 Mitglied von Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 2,368
