Was du brauchst
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
Remove the following two screws under the rubber caps.
Two 14 mm screws using the Phillips #0 screw driver.
Flip up the following:
The two latches holding the two cables shown(white and black)
Pull the cables free from the latches
Lift the keyboard from the computer
Remove the following screws from the inside of the laptop:
Two 4 mm screws using the Phillips #0 phillips screwdriver.
One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
