Zum Hauptinhalt wechseln
Acer Aspire V5-571 HDD SATA Cable Replacement
Was du brauchst
Einführungsvideo
  1. Acer Aspire V5-571 HDD SATA Cable Replacement, Keyboard: Schritt 1, Bild 1 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement, Keyboard: Schritt 1, Bild 2 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 HDD SATA Cable Replacement: Schritt 2, Bild 1 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement: Schritt 2, Bild 2 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement: Schritt 2, Bild 3 von 3
  3. Acer Aspire V5-571 HDD SATA Cable Replacement, Optical Drive: Schritt 3, Bild 1 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement, Optical Drive: Schritt 3, Bild 2 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement, Optical Drive: Schritt 3, Bild 3 von 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 HDD SATA Cable Replacement, Upper  Cover: Schritt 4, Bild 1 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement, Upper  Cover: Schritt 4, Bild 2 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement, Upper  Cover: Schritt 4, Bild 3 von 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 HDD SATA Cable Replacement: Schritt 5, Bild 1 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement: Schritt 5, Bild 2 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement: Schritt 5, Bild 3 von 3
    • Carefully separate the upper cover and remove it.
  6. Acer Aspire V5-571 HDD SATA Cable Replacement, HDD (Hard Disk Drive): Schritt 6, Bild 1 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement, HDD (Hard Disk Drive): Schritt 6, Bild 2 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement, HDD (Hard Disk Drive): Schritt 6, Bild 3 von 3
  7. Acer Aspire V5-571 HDD SATA Cable Replacement, Wi-Fi Half Mini PCIe card: Schritt 7, Bild 1 von 2 Acer Aspire V5-571 HDD SATA Cable Replacement, Wi-Fi Half Mini PCIe card: Schritt 7, Bild 2 von 2
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 HDD SATA Cable Replacement, Mother Board: Schritt 8, Bild 1 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement, Mother Board: Schritt 8, Bild 2 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement, Mother Board: Schritt 8, Bild 3 von 3
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 HDD SATA Cable Replacement: Schritt 9, Bild 1 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement: Schritt 9, Bild 2 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement: Schritt 9, Bild 3 von 3
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 HDD SATA Cable Replacement: Schritt 10, Bild 1 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement: Schritt 10, Bild 2 von 3 Acer Aspire V5-571 HDD SATA Cable Replacement: Schritt 10, Bild 3 von 3
    • Carefully pick up the Mother board and disconnect the Battery cable.
  11. Acer Aspire V5-571 HDD SATA Cable Replacement, HDD SATA Cable: Schritt 11, Bild 1 von 2 Acer Aspire V5-571 HDD SATA Cable Replacement, HDD SATA Cable: Schritt 11, Bild 2 von 2
    • 13 pin SATA HDD Cable Adapter.
    • Did you do it successfully?
Abschluss
ZFix
191.278 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.528 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 4,678
