Zum Hauptinhalt wechseln
Cyber-Shot DSC-H55 SD Card Replacement
  1. Cyber-Shot DSC-H55 SD Card Replacement, Finding where the SD slot is located: Schritt 1, Bild 1 von 2 Cyber-Shot DSC-H55 SD Card Replacement, Finding where the SD slot is located: Schritt 1, Bild 2 von 2
    • The SD slot is located within the battery compartment.
    • The battery compartment is located at the bottom of the camera. If you place the camera upside down with the lens facing you, you will see an arrow with the word "OPEN" under it.
  2. Cyber-Shot DSC-H55 SD Card Replacement, Removing an existing SD card: Schritt 2, Bild 1 von 2 Cyber-Shot DSC-H55 SD Card Replacement, Removing an existing SD card: Schritt 2, Bild 2 von 2
    • Place your thumb on the arrow and while placing some pressure, slide to the right and lift. The battery compartment will be exposed.
    • Once you have the battery compartment open push on the existing SD card and it will pop up.
  3. Cyber-Shot DSC-H55 SD Card Replacement, Inserting a new SD card: Schritt 3, Bild 1 von 2 Cyber-Shot DSC-H55 SD Card Replacement, Inserting a new SD card: Schritt 3, Bild 2 von 2
    • When you look inside the battery compartment you will see a slot with the words "PUSH IN/OUT" next to it. This is where the SD card belongs.
    • First make sure the slot does not already have an SD card in it.
    • Grab the SD card you want to insert, making sure it is an SD Pro Duo card, slide it into the slot and push.
Abschluss
Jazmin Young
608 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 6-2, Brown Winter 2015 Mitglied von USF Tampa, Team 6-2, Brown Winter 2015
USFT-BROWN-W15S6G2
3 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
How much SD card memory will this camera accept? Can I step up to a 64 SD card?
Timothy Conrad - Antwort
Can I use a 64 SD card in the Sony Cybershot, H55, camera?
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 48
Insgesamt: 1,878
