Zum Hauptinhalt wechseln
Toshiba Tecra 8200 Hard Drive Replacement
Was du brauchst
  1. Toshiba Tecra 8200 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the device and unplug the power cord.
    • To remove the battery, flip the device, so that the bottom is facing upward.
  2. Toshiba Tecra 8200 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Toshiba Tecra 8200 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Toshiba Tecra 8200 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Slide the battery to the right side until you hear a click.
    • Carefully remove the battery from its compartment.
  3. Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 3 Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 3 Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 3 von 3
    • Locate the hard drive panel.
    • Remove the single screw labeled F4 by using a Philips size #00 screwdriver.
    • Save the screw, as it will be needed for reassembly.
    • Remove the panel, exposing the hard drive.
  4. Toshiba Tecra 8200 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Toshiba Tecra 8200 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Pull the tab to remove the hard drive.
    • Insert the new hard drive by pushing it into the compartment, leaving the new "pull" tab exposed.
  5. Toshiba Tecra 8200 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Tecra 8200 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Tuck the "pull" tab back into the hard drive compartment.
    • Replace the panel.
    • Replace the single F4 screw.
  6. Toshiba Tecra 8200 Hard Drive Replacement: Schritt 6, Bild 1 von 3 Toshiba Tecra 8200 Hard Drive Replacement: Schritt 6, Bild 2 von 3 Toshiba Tecra 8200 Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Identify the connector pins on the battery.
    • Line up the connector pins on the battery with the connector pins on the computer and push inward to reconnect the battery.
    • Slide the exterior panel towards the center of the computer to lock the battery in place.
Ziellinie
Sally
306 Reputation
3 Anleitungen geschrieben
Ohio State, Team 1-3, Buehl Winter 2015 Mitglied von Ohio State, Team 1-3, Buehl Winter 2015
OSU-BUEHL-W15S1G3
3 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
Awesome Thanks!
Erin Dulac - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 15
Letzte 30 Tage: 21
Insgesamt: 2,237
