Zum Hauptinhalt wechseln
iRobot Roomba 655 Pet Series Front Bumper Replacement
Was du brauchst
  1. iRobot Roomba 655 Pet Series Front Bumper  Replacement, Front Bumper: Schritt 1, Bild 1 von 2 iRobot Roomba 655 Pet Series Front Bumper  Replacement, Front Bumper: Schritt 1, Bild 2 von 2
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  2. iRobot Roomba 655 Pet Series Front Bumper  Replacement: Schritt 2, Bild 1 von 3 iRobot Roomba 655 Pet Series Front Bumper  Replacement: Schritt 2, Bild 2 von 3 iRobot Roomba 655 Pet Series Front Bumper  Replacement: Schritt 2, Bild 3 von 3
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
Abschluss
Rhett
1.329 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-20, Maness Winter 2015 Mitglied von Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 16
Insgesamt: 4,304
