Einleitung
Make sure you don't lose any screws! This guide has you unscrewing in a lot of spots so be careful!
Was du brauchst
Remove the dust bin by pushing on the button for the dust bin removal
Pull the dust bin out
Pull up on the silver handle to release the top protectant plastic
Remove the top plastic carefully
Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
Pull the plastic bumper protector up and off of the bumper.
Flip the Roomba back over, so you are viewing the top.
Pull up on the front bumper to remove it.
Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
Use your Phillips head #0 to remove the one - 7mm bottom center screw
Use your Phillips head #2 to remove the two - 8mm screws by the handle
Push down the two release points to pull the plastic piece up
Pull the plastic piece up
