Zum Hauptinhalt wechseln
Polaroid A10 Battery Replacement
Was du brauchst
  1. Polaroid A10 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 Polaroid A10 Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 Polaroid A10 Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Battery Replacement, Battery: Schritt 2, Bild 1 von 3 Polaroid A10 Battery Replacement, Battery: Schritt 2, Bild 2 von 3 Polaroid A10 Battery Replacement, Battery: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
    • It is better to use a plastic card if you have one.
    • Gently lift up the battery as you continue to separate the glue from the battery.
    • Lift up just enough to see where the glue is, so that you don't bend the battery.
    • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
  3. Polaroid A10 Battery Replacement: Schritt 3, Bild 1 von 3 Polaroid A10 Battery Replacement: Schritt 3, Bild 2 von 3 Polaroid A10 Battery Replacement: Schritt 3, Bild 3 von 3
  4. Polaroid A10 Battery Replacement: Schritt 4, Bild 1 von 1
    • Gently lift the battery up and out of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
armando
150 Reputation
1 Anleitung geschrieben
UW Tacoma, Team 3-3, Rose Winter 2015 Mitglied von UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 735
