Zum Hauptinhalt wechseln
Acer Aspire One ZG5 Wireless Card Replacement
Was du brauchst
  1. Acer Aspire One ZG5 Wireless Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Wireless Card Replacement: Schritt 2, Bild 1 von 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Wireless Card Replacement, Wireless Card: Schritt 4, Bild 1 von 1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Wireless Card Replacement: Schritt 5, Bild 1 von 1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Wireless Card Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Wireless Card Replacement: Schritt 7, Bild 1 von 1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Wireless Card Replacement: Schritt 8, Bild 1 von 1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Doug Gallatin
6.337 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 7-49, Amido Fall 2010 Mitglied von Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 33
Insgesamt: 23,555
