Einleitung
If you would like to upgrade your RAM or if your RAM has malfunctioned, you should pull the chip out and replace it with the desired chip.
Was du brauchst
Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
Four 3.9mm Phillips #1 screws
One 5.8mm Phillips #1 screw
Push out on the first set of metal tabs to release and remove the top RAM chip.
Push out on the second set of metal tabs to release and remove the lower RAM chip.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
