Was du brauchst
Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
Use slight tension to remove the curved base by lifting it upward off of the outside casing.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
