Einleitung
Use this guide to remove the cover from your Optoma HD20.
Was du brauchst
Twist the focal cap clockwise until it is fully extended.
Remove the focal cap by pulling it straight out.
Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
Remove the ribbon by disconnecting it from the main circuit board.
Lift up the clip holding it down and pull the ribbon out.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
