Zum Hauptinhalt wechseln
ComNet Ericsson Panther 600P Speaker Replacement
Was du brauchst
  1. ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: Schritt 1, Bild 1 von 3 ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: Schritt 1, Bild 2 von 3 ComNet Ericsson Panther 600P Speaker Replacement, Locate the release button.: Schritt 1, Bild 3 von 3
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Speaker Replacement, Antenna: Schritt 2, Bild 1 von 1
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Speaker Replacement, Dials: Schritt 3, Bild 1 von 1
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: Schritt 4, Bild 1 von 3 ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: Schritt 4, Bild 2 von 3 ComNet Ericsson Panther 600P Speaker Replacement, Exterior Case: Schritt 4, Bild 3 von 3
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Speaker Replacement, Speaker: Schritt 5, Bild 1 von 2 ComNet Ericsson Panther 600P Speaker Replacement, Speaker: Schritt 5, Bild 2 von 2
    • Locate the device's speaker inside the front panel of the exterior case.
    • Locate the display and speaker stabilizer.
    • Lift the stabilizer up from the bottom and pull the stabilizer out of case.
  6. ComNet Ericsson Panther 600P Speaker Replacement: Schritt 6, Bild 1 von 3 ComNet Ericsson Panther 600P Speaker Replacement: Schritt 6, Bild 2 von 3 ComNet Ericsson Panther 600P Speaker Replacement: Schritt 6, Bild 3 von 3
    • Locate the two 3.75mm screws holding the speaker to the exterior case.
    • Using a T15 Torx screwdriver, unscrew the 3.75mm screws.
  7. ComNet Ericsson Panther 600P Speaker Replacement: Schritt 7, Bild 1 von 2 ComNet Ericsson Panther 600P Speaker Replacement: Schritt 7, Bild 2 von 2
    • Lift up on the bottom of the speaker to detach the speaker.
    • Pull the speaker out of the case.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 183
