Zum Hauptinhalt wechseln
ComNet Ericsson Panther 600P Display Replacement
Was du brauchst
  1. ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: Schritt 1, Bild 1 von 3 ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: Schritt 1, Bild 2 von 3 ComNet Ericsson Panther 600P Display Replacement, Locate the release button.: Schritt 1, Bild 3 von 3
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Display Replacement, Antenna: Schritt 2, Bild 1 von 1
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Display Replacement, Dials: Schritt 3, Bild 1 von 1
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Display Replacement, Exterior Case: Schritt 4, Bild 1 von 3 ComNet Ericsson Panther 600P Display Replacement, Exterior Case: Schritt 4, Bild 2 von 3 ComNet Ericsson Panther 600P Display Replacement, Exterior Case: Schritt 4, Bild 3 von 3
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: Schritt 5, Bild 1 von 3 ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: Schritt 5, Bild 2 von 3 ComNet Ericsson Panther 600P Display Replacement, Front Case - Internal: Schritt 5, Bild 3 von 3
    • Using the plastic opening tool, pry the case apart.
  6. ComNet Ericsson Panther 600P Display Replacement, Ribbon: Schritt 6, Bild 1 von 2 ComNet Ericsson Panther 600P Display Replacement, Ribbon: Schritt 6, Bild 2 von 2
    • The keypad chip is attached to the motherboard by a ribbon.
    • Pull ribbon with tweezers to detach from back panel.
  7. ComNet Ericsson Panther 600P Display Replacement, Screen: Schritt 7, Bild 1 von 3 ComNet Ericsson Panther 600P Display Replacement, Screen: Schritt 7, Bild 2 von 3 ComNet Ericsson Panther 600P Display Replacement, Screen: Schritt 7, Bild 3 von 3
    • Screen will be attached by a ribbon.
    • Pull screen up and away from motherboard to detach.
Abschluss
Daniel
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 210
