Zum Hauptinhalt wechseln
HP ZBook 15 Hard Drive Replacement
Was du brauchst
  1. HP ZBook 15 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP ZBook 15 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Hard Drive Replacement, Back Cover: Schritt 2, Bild 1 von 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Hard Drive Replacement, HP ZBook 15 Hard Drive Disassembly: Schritt 3, Bild 1 von 1
    • Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
    • The screws will remain inside the springs of the hard drive caddy cover.
  4. HP ZBook 15 Hard Drive Replacement: Schritt 4, Bild 1 von 2 HP ZBook 15 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Pull the green tab away from the metal casing and lift the drive out.
  5. HP ZBook 15 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Remove the two 3mm screws on either side of the device with a Phillips #0 screwdriver to remove the drive caddy.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
Grant Terris
2.828 Reputation
12 Anleitungen geschrieben
Cal Poly, Team 8-43, Amido Winter 2015 Mitglied von Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Mitglieder
15 Anleitungen geschrieben
3 Kommentare
You can use Macrium Reflect (there's a free non-commercial version) to backup your disk to an external drive before swapping the drive.
Paul M - Antwort
There is written 'SSD' on its cover, and I'm confused now. Actually I need to disconnect the HDD and then install new OS on the SSD, and now I'm not sure if the drive that you just removed is SSD or HDD because on mine it say SSD. Please help me out.
Sajid - Antwort
how hard disk i can buy for my zbook 15?
thanks
francesco perego - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 46
Letzte 30 Tage: 128
Insgesamt: 28,883
