Zum Hauptinhalt wechseln
Disassembling Garmin eTrex Vista H Motherboard
Was du brauchst
  1. Disassembling Garmin eTrex Vista H Motherboard, Removing Battery: Schritt 1, Bild 1 von 1
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Disassembling Garmin eTrex Vista H Motherboard: Schritt 2, Bild 1 von 1
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Disassembling Garmin eTrex Vista H Motherboard: Schritt 3, Bild 1 von 2 Disassembling Garmin eTrex Vista H Motherboard: Schritt 3, Bild 2 von 2
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Disassembling Garmin eTrex Vista H Motherboard, Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 4, Bild 1 von 2 Disassembling Garmin eTrex Vista H Motherboard, Disassembling the Garmin eTrex Vista-H Outer Case: Schritt 4, Bild 2 von 2
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Disassembling Garmin eTrex Vista H Motherboard: Schritt 5, Bild 1 von 3 Disassembling Garmin eTrex Vista H Motherboard: Schritt 5, Bild 2 von 3 Disassembling Garmin eTrex Vista H Motherboard: Schritt 5, Bild 3 von 3
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Disassembling Garmin eTrex Vista H Motherboard: Schritt 6, Bild 1 von 1
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Disassembling Garmin eTrex Vista H Motherboard: Schritt 7, Bild 1 von 2 Disassembling Garmin eTrex Vista H Motherboard: Schritt 7, Bild 2 von 2
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
  8. Disassembling Garmin eTrex Vista H Motherboard, Disassembling Garmin eTrex Vista H Motherboard: Schritt 8, Bild 1 von 1
    • The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
  9. Disassembling Garmin eTrex Vista H Motherboard: Schritt 9, Bild 1 von 1
    • There are no screws holding the motherboard in place.
    • Carefully lift the motherboard from the case.
  10. Disassembling Garmin eTrex Vista H Motherboard: Schritt 10, Bild 1 von 2 Disassembling Garmin eTrex Vista H Motherboard: Schritt 10, Bild 2 von 2
    • With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
    • Gently pull the wire ribbon from the white connector.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Lauren Noyes
248 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 21-30, Regan Fall 2010 Mitglied von Cal Poly, Team 21-30, Regan Fall 2010
CPSU-REGAN-F10S21G30
3 Mitglieder
5 Anleitungen geschrieben
6 Kommentare
Hello, friend. Name’s Arthur. I have this old Garmin Etrex H GPS device (the yellow one) and it looks very similar to your Etrex Vista H, but it has no stick button. The disassembling method suited just fine here, so I thank you Sir for this tutorial. I was trying to disassembly my Garmin because I am having a problem with its display. There’s a vertical line that its not displaying, so I decided to take a look. However, there was something strange. The display contacts were not locked by a connector, but by something like a durex tape. Seemed very precarious. Have you ever disassembled this yellow Etrex H model? Any ideas on how to solve my problem?
arthurhenriquedefreitasamaral - Antwort
I forgot to remove battery for years and the battery chamber got damaged. So chamber was cleaned and repaired but now I cannot on it.
Posangouri Posangouri - Antwort
My gps often says low battery when the battery is fine.
It just shuts off after a while of saying ‘low battery’.
How can I fix this?
Terry - Antwort
Perhaps I need to take it apart and clean something to do with the battery connection?
I did once have a small battery leak but it all looked good…. did not see any damage.
Terry - Antwort
We have a Garmin etrex vista h..we are using it..but the battery had been leak for just an hour..we opened it.it was still good..but 2days later we opened it.it still open but the bottons are not working..what will we do?
Tonet - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 29
Insgesamt: 7,615
