Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-W55 Lens Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-W55 Lens Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Cyber-shot DSC-W55 Lens Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Lens Replacement: Schritt 2, Bild 1 von 2 Sony Cyber-shot DSC-W55 Lens Replacement: Schritt 2, Bild 2 von 2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Lens Replacement, Back Case: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-W55 Lens Replacement, Back Case: Schritt 3, Bild 2 von 2
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Lens Replacement: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-W55 Lens Replacement: Schritt 4, Bild 2 von 2
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Lens Replacement: Schritt 5, Bild 1 von 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Lens Replacement: Schritt 6, Bild 1 von 2 Sony Cyber-shot DSC-W55 Lens Replacement: Schritt 6, Bild 2 von 2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Sony Cyber-shot DSC-W55 Lens Replacement, Front Case: Schritt 7, Bild 1 von 1
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 Lens Replacement: Schritt 8, Bild 1 von 3 Sony Cyber-shot DSC-W55 Lens Replacement: Schritt 8, Bild 2 von 3 Sony Cyber-shot DSC-W55 Lens Replacement: Schritt 8, Bild 3 von 3
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 Lens Replacement, Lens: Schritt 9, Bild 1 von 2 Sony Cyber-shot DSC-W55 Lens Replacement, Lens: Schritt 9, Bild 2 von 2
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 Lens Replacement: Schritt 10, Bild 1 von 2 Sony Cyber-shot DSC-W55 Lens Replacement: Schritt 10, Bild 2 von 2
    • Gently pull the lens container out of the camera.
Abschluss
15 weitere Nutzer:innen haben diese Anleitung absolviert.
kkfong91
344 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 9-20, Regan Fall 2010 Mitglied von Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 Mitglieder
18 Anleitungen geschrieben
2 Kommentare
Thanks for this guide !
unfortunatly I thinks that my lens is broken (doesn't open anymore, it may have sand inside it)
Do you know where an if I can buy a new lens ?
Erwann Robin - Antwort
Thanks for info..
Need a broken lens unit as my lens cable is broken, email me if any one wants to sell a broken lens unit. at barrettoagnelo@yahoo.com
agnelobarretto - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 26
Letzte 30 Tage: 115
Insgesamt: 22,072
