Einleitung
This guide will help the owner of a Kitchen Gourmet XQ-673H replace the power switch.
Was du brauchst
Using a phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
Remove the bottom cover.
Using a Plastic Opening Tool, carefully slide back the three power connectors for the Power Switch until fully removed.
Gently squeeze the sides of the Power Switch, while using a Spudger to help pop out the Power Switch.
