Einleitung
If your volume buttons are not working properly follow this guide to replace them.
Was du brauchst
Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
Use the slim plastic opening tool to pry the camera from its initial position.
Remove the two screws that hold the volume button assembly in place.
Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
