Einleitung
The Asus Q200E has its battery inside the casing, but the battery is still fairly easy to replace.
Was du brauchst
Turn off the computer and unplug the charge cable.
Turn the computer upside down.
Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
Remove the eight 4.7mm Philips #00 screws holding the battery in place.
The battery is attached by a set of wires.
Use your finger to disconnect the set of wires. It should come off very easily.
14 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Super helpful instructions. Especially mentioning which screws were different sizes, so I knew to keep the 3 different sizes for the back cover separated and noted which sizes went back where. Many thanks!
Great guide. Thanks!
